Need help finding a good pre built pc
Hello, I genuinely have no idea anything about pcs but my pc I currently have is broken. I need a new pc (prebuilt don’t know how to build one). That runs good on gaming/editing/streaming.I would say I have no budget but obviously don’t wanna spend that much my price range is between $1,500 to $2,000 any help would be appreciated! I just need it to run with high high performance that can handle all 3 of those I don’t game In 4k so I don’t know if that helps kinda of competitive “gamer” but I mainly need it with again high performance to handle everything any links with some examples will help thank you!
Go look at the meta pcs and ztt shop since they won’t be selling prebuilts with proprietary part.
You are looking for a good value computer it sounds like. For editing/streaming/gaming, those are THREE categories you want your computer to excel in. This mean you’re going to spend a bit higher to ensure you can complete all of your objectives. I’d save on the storage because that’s an easier upgrade, but have a good core computer to build off of.
You can try this computer and see how you feel? It’s a well balanced computer with an i7 CPU and budget GPU from the most modern family line of gpu’s released.
https://megabotz.ru/abs-favonius-aqua-gaming-desktop-pc-geforce-rtx-5060-intel-core-i7-14700f-32gb-ddr4-1tb-nvme-ssd-fa14700f5060-black/p/N82E16883360882?Item=N82E16883360882&cm_sp=product-_-from-price-options
It also has a price match guarantee as well
Hey there @Mar and welcome to the Newegg Gamer Community forum!
A few questions for you -
  1. How soon are you looking to purchase the PC? (If it’s more than a week from now, there’s not much point in looking. Prices drastically change all the time due to severe market turbulence.)
  2. What kind of games are you looking to play? Be specific with individual titles. Are you looking to just play Minecraft and Roblox? Or do you have some serious heavy gaming in mind like Cyberpunk or Black Myth: Wukong?
  3. What resolution is your primary monitor that you’ll be using to play?
  4. What is the maximum you’re looking to spend?
  5. What part of the world are you from?
With these questions answered, it will be far easier to help you out.
What’s you’re price range?
Are you 100% sure on pre-built?
Yes and my budget is $1,500 through 2,000 and could I ask why most people are against prebuilts? Again I have no clue about pcs still learning I understand building is cheaper but what’s the difference
I would strongly recommend STORMCRAFT. Their quality is great and their support is awesome.
https://megabotz.ru/stormcraft-gaming-desktop-pc-geforce-rtx-5060-ti-intel-core-i7-14700f-32gb-ddr5-2tb-nvme-ssd-sirius/p/N82E16883420027
Both of these are on sale and use top brands in the system
https://megabotz.ru/abs-flux-ruby-gaming-desktop-amd-radeon-rx-9070-xt-amd-ryzen-7-7800x3d-32gb-ddr5-2tb-nvme-ssd-fr7800x3d9070xt-white/p/N82E16883360863
https://megabotz.ru/abs-cyclone-ruby-gaming-pc-geforce-rtx-5070-amd-ryzen-7-9700x-32gb-ddr5-1tb-nvme-ssd-cr9700x50703-black/p/N82E16883360856?Item=N82E16883360856#
